I'm a cocktail newb ... help
Sep 29, 2004
18,656
68
I have the dumbest question. Is Sour Mix different than Margarhitta mix?
I'm going to start stocking a liquor cabinet.
Any simple 2 or 3 part mixed drinks (shots or glass fulls) that you can recommend would be appreciated.
Here's what I am starting with:
Green Tea:
Peach Snaps (1/3 oz)
Sour Mix (1/3 oz)
Jameson Whickey (1/3 oz)
splash of sprite
I had this at a bar and I was shocked at how similar tasting it was to actual green tea. My friend and I agreed, this is more of a sipper to have in a cocktail glass and not as a shot like it was served.
Anyway, get me started!
ElFenix
102,407
8,595
Green Tea:
Sour Mix (1/3 oz)
splash of sprite
that's not a cocktail (t's a daisy) and sounds disgusting. waaaaay too sweet (get rid of the sprite)
this isn't the 70s; sour mix is horrible. if you're making stuff at home use fresh citrus.
They are slightly different. Also making your own mixes make the cocktails taste WAY better. http://www.seriouseats.com/recipes/2012/02/homemade-fresh-sour-mix-for-cocktails-easy-recipe.html
exactly
orange juice
vodka
that's a screwdriver and is a highball, not a cocktail.
a sidecar's actually a daisy, not a cocktail, but still delicious.
I like cranberry and vodka better.
that's a cape cod and is also a highball, not a cocktail
Dr. Detroit
8,604
986
Whiskey & Ice (Scotch or bourbon are fine too)
Negroni - I've drank so much Campari my pee turns pink!
Ruptga
10,246
207
Two parts OJ, two parts pineapple juice, one part Malibu, one part dark non-spiced rum. Add some grenadine on top, just enough to cover the surface. Omnomnomnom
And yeah, they're not the same thing.
FerrelGeek
4,669
266
Try Titos. And yep, cranberry juice is better - add a wedge of lime.
I like cranberry and vodka better. OJ just gets too sweet after awhile. Whats your favorite vodka shorty? I love Stoli but on a budget it's hard to beat Costcos American labeled vodka.
Reactions: SketchMaster
pete6032
8,290
3,698
Step one - buy liquor (gin, whiskey, vodka, tequila)
Step two - pour liquor into rocks glass
Step three - drink
BurnItDwn
26,357
1,869
I believe highballs are subsets of cocktails.
To call a highball "not a cocktail" wold be like to call a square "not a rectangle."
SketchMaster
3,100
149
First:
Sour mix and Margarita mix are not the same. That being said, you'll produce a much better drink if you learn how to mix a drink without that colored sugar water.
Classic Margarita drink: http://www.seriouseats.com/recipes/2015/04/classic-margarita-recipe-tequila-cocktail.html
On building a bar:
My advice is to just pick a few classic drinks that you know you and/or your close friends will enjoy and buy what you need to make those drinks. Try to pick 1-2 classic drinks that use one (or more) of the following base spirits:
  • Gin
  • Tequila
  • Rum (white or dark)
  • Vodka
  • Whiskey (All bourbon is whiskey, but not all whiskey is bourbon)
  • Scotch (for serving neat, or mixing. Yes, you can mix scotch without the world ending. Google blood and sand for a great way to enjoy a smoky scotch.)
If you're not sure what brand to get, go to your favorite bar at a slow time of day, order a beer, and ask what spirit brands are crowd pleasers. If you're in good standing with the bartender, they may give you a few small sips to sample for free. Make sure you leave them a very nice tip for their time.
Don't buy anything you wouldn't drink (unless for a very close friend that comes over often) because then you're just wasting space and money. (Most) Liquors will last on the shelve, but liqueurs and mixers will go bad if left at room temp after opening. If you're not sure if it needs to be refrigerated after opening, put it in just to be safe (sweet and dry vermouth should be kept cool after you open it!). Buy only what you think you can use in three months; it's cheaper to keep buying the smaller bottle every few months than it is to pour out a giant bottle that spoiled. Same goes for bitters, don't buy every bottle you see; just get classic bitters and wait until you learn how to make other drinks that call for more exotic ingredients.
Don't go crazy trying to buy everything all at once, buy what you need to learn a new drink every weekend or so until you know 5-7 drinks off the top of your head. Your cabinet will be stocked with plenty of options at that point and you'll be able to make your standbys without having to stop and look up the recipe.
A drink is only as good as the sum of its parts. Use good quality spirits and if a drink calls for juice try your best to make it fresh (lemon/lime is stupid easy to squeeze). Simple syrup is easy to whip up in small batches, learn how to make it (hint: its name should give you an idea of how hard this is).
Don't deviate from the recipe until you've made it a couple times, then start to experiment.
Cheers.
Reactions: IHateMyJob2004
Exterous
20,607
3,827
Blasphemy!! Get whiskey stones!
Clearly Jeebus has been spending too much time eating his fruit and can no longer stand the full manliness of un-watered down Scotch. In a few more years I predict he will reduced to putting ice cubes in his new favorite drink: Natty Ice.
Reactions: FerrelGeek
SketchMaster
3,100
149
Depending on the scotch, I'll either add a splash of water or a single cube of ice to open up or mellow the scotch.
SketchMaster
3,100
149
"open up"
"mellow"
Cask strength, neat, thx.
Don't knock it 'til you've tried it. I was also skeptical at first, but after trying a splash of water in my favorite scotches I was sold. New scotch I'll have neat, but after a few times, I'll start to play with water ratios.
Adding a splash of water to a scotch is like plugging your favorite pair of headphones into an EQ. You get to tune the sound to appreciate a song in a slightly different way that's more pleasing to you.
