Why would Iiyama keep "a large supply" of an item they're closing-out? The monitor was discontinued last November, so I don't see them having any sizable inventory. And unless they have had a lot of problems with this specific monitor, why would they have any significant inventory of refurbished units?
Most manufacturers of good quality merchandise send out new items to replace warranty claims - then resell the refurbished items to recover their loss. Unless the item is specifically marked as a refurbished item, how would the manufacturer know the item is refurbished (except in cases where you purchase directly from the manufacturer), especially if you do not send in the registration/warranty card?
If this monitor came with a standard warranty (like many other manufacturers' do with their refurbished units), I wouldn't have any concerns. But buying a monitor that only carries a 90-day warranty seems like a considerable risk, especially given that the unit has had problems or already failed once.
"The ones for sale for $349 are refurbs. if you have a problem with one, Iiyama is the manufacterer, so I assume they have a large supply, but I don't think your going to get a new one if your refurb. goes bad, you will get another refurb."
