IIS help (WinXP Pro)
Ichinisan
28,298
1,235
I'm using the IIS component that was included with Windows XP Pro. I ripped an audio CD and zipped the files, then copied the zip file into C:\inetpub\ftproot
The archive's filename is "acm_test.zip". Internet Explorer can see the file at ftp://localhost/, but it cannot download it. The WinXP SP2 Firewall is completely disabled. I enabled the IIS WWW component and copied the file into C:\inetpub\wwwroot\michelle (for my sister). http://localhost/michelle/acm_test.zip gives me the same "not authorized" error message, only in HTML form. I created an index.htm file with a link to the file (<html><a href="acm_test.zip">test</a></html>) and I still receive the "not authorized" message when I click the link. If this is a permissions issue, why would I be able to download the index.htm file and not the zip file?
Now I just tested the FTP again and it's working (#$@$!!!?), but not the HTTP server. What can I do?
Ichinisan
28,298
1,235
You are not authorized to view this page
You do not have permission to view this directory or page using the credentials you supplied.
Please try the following:
Click the Refresh button to try again with different credentials.
If you believe you should be able to view this directory or page, please contact the Web site administrator by using the e-mail address or phone number listed on the jevansturner.gotdns.com home page.
HTTP 401.3 - Access denied by ACL on resource
Internet Information Services
Technical Information (for support personnel)
More information:
Microsoft Support
Ichinisan
28,298
1,235
What should I look for under file permissions?
C:\Inetpub\ftproot
Folder Properties>Security
-Administrator
--Special Permissions (selected, disabled), all others are not selected
-Administrators
--Full Control (all selected, disabled)
-CREATOR OWNER
-SYSTEM
-Users
--Read and Execute (selected, disabled)
--List Folder Contents (selected, disabled)
--Read (selected, disabled)
--All others permissions not selected
C:\Inetpub\wwwroot
-Administrator
-Administrators
-CREATOR OWNER
-Internet Guest Account
--Write-Deny, Special Permissions-Deny (disabled)
-Launch IIS Process Account
-SYSTEM
-Users
Ichinisan
28,298
1,235
The properties on the file do not have the Internet User Guest Account listed.
I have not changed any of the default settings since the IIS WWW component was added. It should not be doing this...should it?
WannaFly
2,811
under default website you need to create a virtual directory for /michelle/ ... right click on "default web site" then "new" then "Virtual Directory" it is alike 2 steps after that, pretty simple - post if that doesnt work.
Ichinisan
28,298
1,235
I just deleted the file from wwwroot and copied the identical file from ftproot and it worked, which doesn't make any sense. They were *both* copied from My Music. How did one get different security permissions than the other?
Grr :mad:
