mcveigh
OK, 2002 camry. I got home the other day. Switched the car off and pulled out the keys. I realized the car was still running. I can put the keys in and out and turn, but nothing happened. I had to open up the steering column to unplug things from the ignition, then it turned off.
I can't turn it on though. WHere you expect that spring loaded resistance to start the car, there is none.
I've found replacements locally. But I can't find any good pictures/diagrams/videos of how to pull the old one out. I can find info on previous generations, but it doesn't seem to apply to mine.
Does anyone have an idea on howto pull the ignition switch on my car?:wub:
