Background:
Before whenever our Desktop group used Altiris to image PC's & laptops, it became broadcast because no PIM RP was available to facilitate the register process (I think), even though the sender & receivers are all in the same vlan.
So we simply implemented PIM routing on the core L3 3560 to enable multicast.
Question1:
Would the image that the source sends have to traverse through the L3 3560 (PIM router), and then back down the tree to reach the receivers?
Or would the multicast stream propagate through the access / distribution switches, w/o having to go through the 3560 first?
All the switches have IGMP snooping enabled.
Most of the multicast documents I've read seem to only cover forwarding scenarios based on L3 PIM routers, and not L2 switches.
While I have a basic understanding on how multicast forwarding & IGMP snooping work, I'm clueless on how the multicast stream looks like on a LAN.
Question2:
Follow-up to Q1, if the sender & receivers happen to be on the same L2 access switch, would the multicast stream reach the receivers directly, or would the stream go up to the PIM router (L3 3560), and then back down to the L2 switch?
Question3:
How would the scenario change if sender & receivers are on different subnet/vlan? (assuming PIM is enabled on all SVI's)
Would an access switch have different snooping tables for each vlan?
Or would multicast stream have to be PIM routed by the L3 switch?
Question1:
Question2:
Question3:
