If you removed all the dissolved air from water, and revved a prop in it, would cavitation still happen?
Fullmetal Chocobo
Moderator<br>Distributed Computing
Moderator
May 13, 2003
13,704
7
I don't believe cavitation is releasing the dissolved oxygen in the water, so much as it is creating a pocket of low pressure.
More importantly, do the toilets down in Aussie actually flush in the other direction??? And what if you are on a ship, and you flush the toilet, and then cross the equator?
dug777
24,778
4
Originally posted by: jagec
of course. water has 3 phases.
thats what is suspected, cheers :)
FmC: the coriolis (sp) effect is overruled in most cases by the bowl design iirc...
Fullmetal Chocobo
Moderator
May 13, 2003
13,704
7
:( Go drain some water from the bath tub, and let me know. :D
CaptnKirk
10,053
Cavitation is caused by frictional heating of the water by a propeller causing it to boil in a reduced pressure area.
32,185
Yes, that is why Aussies smell the way they do.
Rogeee
622
Cavitation is caused by a low pressure area at the trailing edge of the prop, it has nothing to do with raising the temp of the water, as pressure decreases the boiling point drops, the water does not get heated up, the same applies in reverse, if you pressurise water, the boiling point raises, this is why you have a pressurised cooiling system in your vehicle, it raises the boiling point of the coolant thus preventing air pockets from forming in the cooling passages of your engine.
loic2003
3,844
A vortex opens.
If you flush exactly on the equator it doesn't roatate at all apparantly. Just goes striaght down.
loic2003
3,844
Wikipedia is your friend:
Major places where cavitation occurs are in pumps, on propellers, or at restrictions in a flowing liquid.
As an impeller's (in a pump), or propeller's (as in the case of a ship or submarine) blades move through a fluid, low pressure areas are formed as the fluid accelerates around and moves past the blades. The faster the blades move, the lower the pressure around it can become. As it reaches vapor pressure, the fluid vaporizes and forms small bubbles of gas. This is cavitation. When the bubbles collapse later, they typically cause very strong local shockwaves in the fluid, which may be audible and may even damage the blades.
Nothing to do with air wihtin the water.
