If you own an air compressor, isn't there an easy attachment to allow a garden hose to work as a pressure washer?
jonnyGURU
Moderator <BR> Power Supplies
Moderator
Oct 30, 1999
11,815
104
How much and who?
Ornery
17
Just a few bucks at WalMart or Sears, but it doesn't heat the water. It's just a $12.00 nozzel that attaches to the garden hose and air hose. But it's the super hot water that really does the work on the preasure washers.
jonnyGURU
Moderator
Oct 30, 1999
11,815
104
I could always attach a hose to the drain on the hot water heater in the garage. :p
Soybomb
9,506
Actually ornery I have that one from walmart. Its more of a mister that you drop an attached hose in for like spraying a degreaser in an engine bay or something. It is very low pressure. I think you're looking for something that will blast away the grime. I know The Eastwood Company sells what you're wanting though for like $30
edit: I take it back: their &quot;GRIME BLASTER WASH NOZZLE &quot; is about $55, but it sounds like what you want....
jonnyGURU
Moderator
Oct 30, 1999
11,815
104
I ask because it's only $15.
Here a picture.
For $14 vs. $55 there's a big difference. The $15 is the same as WalMart's $14 which only mists?
SuperSix
Soybomb's on taregt. I have an Eastwood catalog I could bring in JOnny, but I would go with the Eastwood unit. But with the Lowe's unit, you can return it if you don't like it. ;)
Ornery
17
Yeah, I missed the mark on that one. I tried making one myself, but it needs check valves to keep the water from going into your compressor or air into your water line.
I bought the $15.00 job, but forgot that it doesn't hook up to the water line.
If you just have a couple jobs to do, like power washing your house, you could rent the real thing for a few hours. Do your car engines too while you have it. Perhaps your neighbor would go halves on the rental.
sharkeeper
10,886
I remember something called a Thunder Gun from the 80's. It was featured in Popular Mechanics magazine and I believe Sears may have sold it. Coupled with a 1 HP or greater air compressor (5 CFM @ 90 PSI) and a water hose (50 PSI) it was capable of the same power as a 1,000 psi pressure washer.
I picked up an electric start 4500 psi @ 4.2 GPM gas pressure washer with a kerosene heater for HOT water at an auction for $200! The state used them to remove graffiti and to wash industrial equipment. It really needs to be turned down low before you point it at a car, however.
Cheers!
jonnyGURU
Moderator
Oct 30, 1999
11,815
104
I've done the rental route and it adds up fast.
SuperSix: Bring that catalog! I'll pull the trigger and buy the $55 one, I think.
Soybomb
9,506
Yeah jon that one you posted the picture of is just like my walmart one. You get to drop a small hose in a bucket of solvent, but thas is :(
jonnyGURU
Moderator
Oct 30, 1999
11,815
104
What about hooking a hose up to the water heater? Is that a stupid idea (because there's no cold)? It's not like I'm going to spray anyone with it. I've shot myself in the foot with a pressure washer. NOT COOL. Hurts like a mother. Never again.
Soybomb
9,506
I assume you mean you'll run a garden hose fomr the hot water heater to the sprayer, but what sprayer are you going to use? The cheap ones have like a 1/4 hose that is meant to siphon a fluid from a jug. If you mean running it to the big one.....I dont see why not.... as long as you can hook it up to a valve to turn it off ;)
jonnyGURU
Moderator
Oct 30, 1999
11,815
104
The more expensive one looks like it has a standard hose attachment. The water heater has a valve. I'm thinking of going that way. As long as I don't get any water on me, I should be fine. :p
Soybomb
9,506
I think you will be too :) I assume you're talking about the valve on the bottom of the waterheater that is supposed to be used to drain it and not the one on the top that is hooked up to the pressure release? :)
jonnyGURU
Moderator
Oct 30, 1999
11,815
104
Yeah. I'm talking about the bottom of the water heater. That looks like the same thread as a water hose, right? ;)
Pastore
9,728
that hotsy looks like it wants to pick a fight with me... what planet is it from?
