If you own a Shuttle SN25P & 7800GT I need your help
sausesq
7
It took a week, but I finally got the 6 pin PCI-Express power supply adapter cable with two 4 pin Molex connectors from XFX. They forgot to include that required cable (as well as the product manual) in the retail xfx 7800GT box I bought from Newegg. See:
The cable I am trying to connect
How exactly do I connect that cable from my GPU since the SN25P power supply does NOT have enough 4 pin molex inputs cables coming out of the PSU [labeled with a P and then number]. As you can see, I need 2 free molex connectors to input the two ends into to power this GPU and I can't find any in my case. I'm sure what the correct terminology is for some of this stuff so pardon my ignorance. To make matters worse the adapter cable is so short and the GPU card is so long and close to front of case I don't know how I would connect it even if they were there.
What I am missing here? I read the manuals and they had no info. Is there more info. on the SN25P PSU online with a diagram or something? Does anyone have any pics of there power connections they could share or instructions? I only have two SATA hard drives and a DVD-RW drive connected now [using P6 and P7 is not used because it is too short] I am not using a floppy drive. I need to know how to set up these power connections to the PSU otherwise I can't set up my system so any help would be appreciated.
Megamixman
150
Splitter Cables? Get 2. Split one cable to 2 then connect the other splitter to one end and you have 3 connectors, 2 for the XFX cable and 1 for whatever was connected there before. I know my local CompUSA (cringe) has extension cables for the molex connectors.
