If you have a noninterference engine and timing belt breaks..
Philippine Mango
5,594
Nothing catastrophic will happen to the engine, correct? Remember, NONinterference engine and timing belt breaks. Now I ask, if the timing belt were to break on such an engine, how would you fix the problem? Would this still be a costly repair because you need to somehow get the pistons and valves synced up again? How would one go about doing this?
Ilikepiedoyou
685
If it breaks nothing goes horribly wrong, however the car must be towed. You "sync" up the valves and crankshaft the same way you would when normally changing a timing belt. Marks at TDC are provided on both the cam gear(s) and crankshaft pulley. Any normal mechanic could probably do this.
KLin
30,941
1,070
lol 5013 posts and you're only a member. Funny. How's Goku?
Philippine Mango
5,594
He seems alright but I really know that hes PO'ed. Kinda funny, since he can't login anymore, now I can use the forums.. :p Still not fair what the mods did but at least I came out on top...
skyking
22,887
6,050
follow the instructions for replacing the timing belt. Proper alignment of the cam and crank is a part of that procedure.
apex32
641
Well that should help so what else do you need to know. Nothing catastrophic will happen. Get it towed and do it yourself, by using a shop manual or pay a trusted mechanic to do it for you.
Philippine Mango
5,594
don't you need one of those timing lights?
Squisher
21,204
66
Repair is usually around $400. This usually because there will be a bunch of stuff to take off to get to the belt. Syncing it isn't a problem.
I could get it done in between 5 and 7 hours. A good mechanic, maybe 3-4.
phoenix79
1,598
Mine broke in my 93 camry and it was fine. $250 at the dealer and all was well again
Kaieye
I was driving about 70mph in the fast lane (On Int. 280 just south of San Francisco many years ago) and the car just stopped running as if the ignition just stopped. The timing belt broke!
Yes, it was exciting but I don't want to go thru that again. Can you imagine your girlfriend or wife driving if the engine just lost power?
