Originally posted by: Pacfanweb
Originally posted by: CantedValve
You gotta reduce the stroke. Try putting in a standard rotating assembly. That will return it to the compression it should be (10:1). Actually, it will be a bit higher due to the overbore.
I dont think there are a set of heads out there that will fix this. Maybe dished pistons, but even then, they would have to be SUBSTANTIALLY dished. Shorter rods wont get it, cause the further below deck you get, the more likelyhood of detonation.
Get the stock 3.750" crank, stock rods, and stock pistons (in the appropriate size).
Reducing the stroke won't reduce compression, at least not in a measurable amount. If the compression is that high with flat-tops, then chances are, the block has be decked a fair amount. You can make up some of this by running and extra-thick head gasket. Dished pistons, like I mentioned earlier, will do it also.
The compression height of those pistions has to be pretty high. Changing to different flat tops may help. I don't think any one thing is going to get you all the way to 10-1. It's going to have to be a combination of things.
For what it's going to cost you in parts and machine work, you can buy a LOT of racing gas or octane booster.
Edit: Let me clarify something: Reducing stroke will mean you have to change the pistons also. You can't change the crank without changing the pistons. That would be basically the same as changing just the rods.
If you changed the crank, you'd need pistons with a lower pin height to go with the shorter stroke. The piston would still be in the same place at TDC. (top dead center)
All you'd have is the same exact engine with a few less cubic inches, which would, SLIGHTLY, lower the compression, but it would be a lot of work for very little change. You could change the compression more with thicker head gaskets. In fact, thicker head gaskets would be the cheapest and easiest way to lower compression.
I still believe that you'll need more than just one change to get any significant change, though.
