futurefields
I want to get this card
http://www.amazon.com/gp/product/B0...82-f600-4071-83a2-04403f02649f&pf_rd_i=284717
So I can run a firewire audio interface on my PC
http://www.amazon.com/Focusrite-Saf..._UL160_SR160,160_&refRID=0WM0ERTRM1Z2WNT459TJ
My question is, since my motherboard has two PCI-X16 ports but doesnt do both at X16 at the same time does that mean there is a chance the GTX970 plugged into my main PCI x16 port will have reduced bandwidth if I do plug that Firewire card into the remaining X16 slot on my motherboard?
There is also an dedicated PCI-e X1 slot located above the GPU which would probably be ideal to use but I'm not sure if there is actually room for the card there...
