If when u installed the HSF, the part of the HSF that makes contact with the CPU was made of copper... The orange/redish metal.Originally posted by: BillStuck
I dunno. What is the stock P4 HSF made off copper?
It probably had some white stuff.Originally posted by: Viper96720
Did the underneath of your heatsink have some black stuff?
It's better at disapating heat from the CPU then aluminum in cheaper coolers
I scraped off the thermal pad and put some Compusa brand silver thermal compound. Temps are still about the same.
But I did do one thing that seems to have dropped 3 or 4 degrees C off my temps. I took my 120mm exaust fan and turned it around so it blows in. I duct taped a piece of foil cloths dryer tubing to the fan and pointed it down right on top of the CPU fan. Since I no longer have exhaust I removed 5 empty PCI slots so the air flows out of there.
What do you guys think of this? Looks pretty jerry rigged, but so far it seems to have dropped my temps a few degrees.
