Originally posted by: Heisenberg
Edit: Jesus, you people need lives.![]()
Congratulations, you're the 9,212th person to make that joke.Originally posted by: nourdmrolNMT1
your certain we all need lives huh? how can you be certain?
MIKE
MIKE
MIKE
MIKE
you're certain he's the 9,212th person to make that joke, huh? how can you be certain?
You know, when they get around to inventing that device that will let you smack people in the head over the internet, I'm going to be the first in line.Originally posted by: Amorphus
MIKE
Originally posted by: BillGates
put some Panaflos around it - cheap 12v cooling!
Originally posted by: bmacd
like BillGates suggested, i recommend at least (2) 12v fans running across your cooling fins (both fans flowing in the same direction) to drop the temp a little bit. As far as your amp cutting off, you may be using too much power, or exactly the opposite, clipping your amp, in which your amp will go into a "standby" or "protection mode" to avoid further damage. Verify that you have a good ~12-14 volts going to the amp when your car is running. If you DO buy fans, DO NOT splice them into the power for your amp; run a seperate line and split that if need be.
-=bmacd=-
edit: fyi: when you "crank up" your volume on your HU, you're putting a big load on your amp. Try to adjust your gains to match your listening preference, that way the amp may not have to work as much. Also, don't listen to your music so loud...you're going to do severe damage to your ears, and once your ears are gone, there's no fixing them.
<--21 year old who went through the same phase as you a few years ago. Regrets everyday of buying loud subs.
-=bmacd=-
meh...you really dont know much do you?
RF amps will not go into protection mode and stop putting out sound altogether. They will play until they are dead. You shouldnt need additional fans with such a simple setup. It sounds like a bad amp. If his other amp is still playing, then most likely his RF amp is just bad, especially if its cutting out altogether.
To the OP: do your lights dim when you get a bass hits real hard?
-=bmacd=-
No, my lights doesn't go dim when hit hard
-=bmacd=-
take it to the place that installed it. If thats where you bought the amp from, they should either fix it, or give you a new one. If you didnt buy it there, they will at least be able to confirm/deny that you have a bad amp.
It sounds like he bridged the amp and wired the subs in parallel. By doing that, you lower the impedance the amps sees and therefore get more power. But it has the downside of making the amp work much harder than wiring them normally which I'm sure contributed to the overheating (if it is overheating and not shutting down for some other reason). Since you wired them normally, that should help with the overheating but you'll probably need to turn the gain on the amp back up to get a decent sound output.Originally posted by: krisoto
alright, i think i got this right. the way the installer wired my sub to the amps is the two right are in 1st (+)channel and the two left are in the 2nd channel(-). now i set it in the right place left and right in 1st channel and left and right in the 2nd channel. so far so good, the amp didn't went to the protection mode but now, i lost the big bass sound. i don't know why the installer did that. any clue??
