If I were to get a new Apple 23" HD LCD Monitor, wut adapter would I need for it to work on a PC?
Mik3y
Banned
Mar 2, 2004
7,089
Mik3y
Banned
Mar 2, 2004
7,089
i mean as an adapter to the video card, since i hear it requires something different. tell me if i'm wrong or not.
airis2001
308
I think that apple sells a DVI to ADC (apple/mac standard connection) I am pretty sure i saw one in a case at compusa (with teh i-pod toys, go figure). Isn't the ADC pretty much a DVI port but with the power on the same plug as the video feed? I think i read that somewhere a while ago, can't ermember where
Yomicron
1,735
The new Aluminium cased LCDs use DVI and should work with a PC out of the box. The older LCDs require an ADC-->DVI adapter to work with a PC.
Wahsapa
3,004
if you buy the NEW lcd you dont need an adapter, its DVI. it you get an OLD lcd monitor(which you shouldnt) you would need a DVI-ADC adapter. try searching the apple website
nickmarine
191
None,
I have the old 23 and its ADC whic=h is Apple all the way but I'm getting the new one which is DVI and can be used for both PC and Mac.
Nick
usernamemax20charact
2,863
As Yomicron, Wahsapa, and nickmarine have stated, the new Apple LCDs are only DVI. So if your graphics card has a DVI connector, you'll be okay. Otherwise, you'll need a VGA to DVI adapter. And out of the box, they work with both Macs and PCs. Trust me, if there's one thing I know, it's Macs.
Eug
24,169
1,812
I find that some cheap PC DVI cards have crappy DVI signals. They don't work consistently with all displays. Just make sure you have a good quality DVI card and you should be fine. However, you'll need to set a custom resolution of 1920x1200 (for the 23"), if your card's drivers don't already have that built in.
