Well the temp readout isn't done on the power connection only the RPM readout is. The temps comes from the socket thermistor either under the socket, behind the socket, etc Since it varies from differing boards.
i read in another post here that you could split the connect and send 1 pin to the mobo and the other to a 3 to 4 pin adapter. Sorry i cant tell you more
