if i remove battery and change my phone screen will i lose data?
OBLAMA2009
6,574
if i remove the battery for an extended time in order to change my screen will i lose any settings or photos etc...?
WelshBloke
33,392
11,536
You wont lose any data. {edit: if you do it correctly}
What phone are you changing the screen on?
Some of them can be tricky, got a good guide?
gorcorps
aka Brandon
Jul 18, 2004
30,741
456
Whenever there's any shred of possibility that you're going to lose data, always back up.
always
I don't care if somebody did the exact same thing 1000s of times in a row without issue, always have a backup.
vshah
19,003
24
do a backup. supposing your screwdriver slips and you stab the flash chip? anything could happen with the phone opened up.
OBLAMA2009
6,574
its my old droid x phone. i watched the youtube video from repairsuniverse, do you have other tips?
OBLAMA2009
6,574
always
yeah im thinking you guys are right i should backup. theres no quick easy way to transfer 600 or more photos though is there?
WelshBloke
33,392
11,536
I've no experience of moto phones. Is the glass, lcd and digitiser all fused/glued into one piece? If it is don't do it unless you get a full replacement unit (screen+lcd+digitiser and surrounding housing) unless you don't mind killing your phone and are a masochist.
Plug it into your pc and let it transfer them?
OBLAMA2009
6,574
no its just the lcd that needs changing and thankfully its not fused to the digitizer.
when you transfer files do you have to do one at a time?
WelshBloke
33,392
11,536
... when you transfer files do you have to do one at a time?
Depends on what you want to backup.
If it's just photos and videos I'd either just plug it into the PC and let windows automagically suck them out or let Google+ back them up to the cloud (actually I'd do both on a regular basis).
I use Google services for email, calendar, contacts and the like so they are independent of the phone anyway.
For sms/mms you might need sms backup+ if moto don't provide a solution.
I'd probably drag and drop the whole storage of the phone (internal sd and external sd) to a folder on my desktop as well just in case there's anything else that I forgot after doing a nandroid and titanium backup.
OBLAMA2009
6,574
if all i care about are my photos (i dont really use this phone anymore) are dragging and dropping the best way? i dont know what nandroid and titanium backup are. how long will 600 photos take? i recall trying this before and quitting when it took so long...
WelshBloke
33,392
11,536
if all i care about are my photos (i dont really use this phone anymore) are dragging and dropping the best way?...
Are the photos on an sdcard or the built in memory?
Dragging and dropping is fine.
(and back up more often in future ;) )
WelshBloke
33,392
11,536
im not sure, probably built in memory, although there is a micro sd card in it as well
Its usually quicker to get things off the memory card by removing it and connecting it to the computer directly (card reader or adapter).
