If i reformat drive C: and all my games are on D: - will i have to reinstall them?
o2brew
118
For any of the games that store settings etc in the registry you would have to reinstall. Some games and applications don't need any registry entries to run, those would be ok. Those are becoming increaslingly rare though.
styrafoam
2,684
Some games save their profiles and save games(microsoft games esp) to My documents/my games. Back those up before you format C: if you have any.
Sunner
Originally posted by: Philippine Mango
yea but the problem is registry entries for games can be VERY DEEP in the registry making it impossible.
I don't remember which one, but there was one game that actually saved all the settings as a .reg file, so if you reinstalled/moved to a new computer, you could just import this reg file.
boran
1,526
I think you'll have to reinstall, as mentioned previously, make sure they dont store anything on C, Games such as NFSU2 store the savegame on your C (very hidden even), so make sure you have all savegames accounted for (ask here if you cant find a savegame for a peticular game).
sandorski
70,698
6,257
If you haven't tried already and are using WinXP, do a Repair Install. Nothing will need to be re-installed and many a problem has been solved using Repair.
funggorgor
257
yes, of coz you need to reinstall them
otherwise you will miss all the registration and dll files
Joemonkey
8,859
4
i do this once every few months, and out of the 10 or so games i play, 9 of them do NOT need to be reinstalled!
Sunner
Again, there are games, quite a few of them in fact, that will work even after a reinstall.
It's all up to how the game stores data.
In many cases a reconfig might be needed, in some others, they'll run just fine the way they were, sans start menu objects etc.
imported_jediknight
343
Most games are well behaved and place all of their registry entries in HKEY_LOCAL_MACHINE\SOFTWARE. If you backup the necessary keys, everything should work. Saved games may be a different issue - some store them in my documents (which may be on your c:\ drive if you haven't changed it).
I wonder.. is there a program that will let you see the differences in your registry (ie. before/after installing/running a program)? Such a thing would be useful in this regard..
Dec 27, 2001
11,272
How often do you reinstall? I do it once a year and don't care if I need to reinstall the 3 games I'm still actually playing of the 14 I had loaded. If I look at the disc and don't feel the wait to install it outweighs the desire to play it, I put it on Ebay. ;)
DaveSimmons
40,730
670
This is where having an image of C: could help you -- restore the image instead of reformatting, and any games installed before the image was made will definitely work.
Navid
5,053
You are going to lose the shortcuts in the start menu of course. But, you can copy them back.
Many games place saved games in the "My Documents" folder. In my case, the "My Documents" folder is also on D. So, I have no problem with the save games. You should back those up before reformat.
I play some first-person shooters (Thief, Hitman, Iron Storm, Half-Life, Counter Strike, Half-Life 2, Red Faction (and 2), Far Cry, Soldier of Fortune, IGI2, ...). The only game I have had that absolutely needs a re-install is Halo. Far Cry needs a re-install. But, I have copied about 10 dll files that I restore after a reformat and it does not need a re-install.
