They have little things that the nail goes in at like a 45 degree angle down, and a little piece that goes on it. Then the part on the picture hangs on that. So, basically what Anubis said.
yeah, I work in a frame store, we give these little hooks that you nail into the wall at an angle with the frames. Go to your local frame shop, they should give you some for free
