Originally posted by: Howard
Depends on the driving style, mass of the car, drag coefficient, etc. In fact, it's the same as asking how far you can get with an engine of n% efficiency, except that n is now 100 (or 1).
Pretty much.
OP: Keep in mind it is not just the frictional losses in an engine that sap power. Although lots of the energy from the gasoline is lost through the tailpipe, and the cooling system (ICE's create loads of waste heat) there are also parasitic losses in the driveline, rolling resistance in the tires, etc. Air resistance is a big one though, as far as traveling at higher velocities.
To be honest, I think that combustion efficiency in ICE's are fairly respectable, considering what they where not more than 15 years ago.
Getting the rest of the parasitic losses down is a lot trickier, especially as the average consumer demands more and more from their automobile. Things like airbags, CD changers, etc., do not come free, and the bloating of automobile curb weights is plain evidence of that. The Prius is one of the very few automobiles that tries to save energy at every corner. It has a special insulated coolant tank that keeps the coolant warmer longer, saving the need for wasteful warmups. It also tries to only use the combustion engine at very high loads, to save on pumping losses, by the electronic throttle and IMA.
So, to reiterate, your question is rather vague, but does invite a lot of discussion. Maybe you should lock it down to a specific vehicle?
To try to put this in perspective, gasoline has about 34.8 megajoules of energy per liter. About 6.96 of that is delivered to the flywheel, which is sapped even more from the driveline losses mentioned earlier. ~12.53 of that is lost as thermal energy through the cooling system, whether through the radiator or HVAC system. ~13.2 is lost through the tail pipe as thermal energy, or unburned hydrocarbons, although the unburned hydrocarbon but has been declining for quite a while.
Originally posted by: DrPizza
I'm assuming that by 100% efficient, you mean you can use 100% of the gasoline's energy to propel the vehicle. I don't think it's useful to hypothesize that there's zero rolling resistance, zero air resistance, etc. So, as now, it'll still depend on the vehicle. Larger/heavier vehicles will still get lower mileage than lighter, more aerodynamic vehicles.
Originally posted by: nboy22
But in all basics, a close to 100% efficiency is not plausible inside our universe, correct? unless there is some sort of physics that we don't know about, won't there always be something to hinder the efficiency?
If you assume that your current engine is 30% efficient, your new engine is 100% efficient, and all else being equal, then your future gas mileage could be estimated as current mileage * 100/30. So, my car got about 27 mpg this weekend (best it's gotten in 10 yearsOriginally posted by: nboy22
Of course, I was just wondering more of a, "What if?" type of scenario.. Not realistic at all but I just wanted to know what would happen in such a situation.
Originally posted by: f95toli
the only way to really save fuel is to use hybrid engines n smaller cars with less drag and friction.
That's why it irks me when the Oil Company supporters push for more and bigger SUV Hybrids.
Originally posted by: Nathelion
Could we please keep the sable rattling out of this forum?
Do you know what forum you stumbled into?Originally posted by: dmcowen674
Well.. let's say a car that's 3000 pounds and has 24 MPG with the 35% effieciency, I guess if it was 100% efficient it would be close to 70 MPG..
Originally posted by: themisfit610
I read a fascinating article about making use of the excess heat generated by internal combustion engines, particularly of the gasoline type.
Essentially, you have a six stroke engine, in wihch the first four strokes are the typical intake, compression, combustion, exhaust stages, but after this you have two stages where water is sprayed inside the piston to collect as much of the heat as possible, which therefore turns into steam, and forces the piston down again. This system has shown up to a 50% improvement in efficiency over an otherwise identical gasoline engine, though it shows only moderate gains in diesel engines.
Imagine a high temperature turbocharged engine that could somehow extract heat energy from the turbo and engine block! Maybe even cool the intake charge at the same time somehow?
~Misfit
~Misfit
... Popular Mechanics?
Why even consider the 100% efficient engine when it is, as Mark pointed out, physically impossible? It would be more useful to consider an engine that is as efficient as physically possible.
If you mean anything like a Wankel-cycle motor, that's 100% false.Originally posted by: Captain Howdy
~Misfit
Like an electric motor, and maybe using the braking energy and extra engine torque to recharge the batteries?
Really even a gas turbine engine is quite a bit more efficient than typical reciprocating piston engines. Rotary engines get a bit closer
Really even a gas turbine engine is quite a bit more efficient than typical reciprocating piston engines. Rotary engines get a bit closer, but still can't get close to the max 90% efficiency of a gas turbine used with cogeneration.
Originally posted by: firewolfsm
If we could develop a way to convert large amounts of heat into energy efficiency could go up 20%. It's being researched for electronics as a way of cutting down heat and improving battery life but it could be used for so many things. Currently they have about a 50% efficiency, imagine half the heat from cars going back as energy.
