If fax machines work on Vonage/VOIP...
SunnyD
Belgian Waffler
Jan 2, 2001
32,675
www.neftastic.com
Naturally a regular modem should to then correct? Basically the same technology. The caveat, probably have to slow the modem down to about 9600, 14.4Kbps at best (as that's the best a fax machine these days handle) correct?
I'm trying to troubleshoot an ISP issue for my brother, but being that he's here and I don't have a landline, this is going to be quite bothersome...
imported_goku
7,613
Yea I was wondering how if you were to dialup, what your dialup speeds would be. 53k? I'd imagine i'd be fast because of the zero noise on a VOIP connection.
PlatinumGold
23,168
according to vonage, fax over a modem in your PC won't work. i had vonage and could never send faxes from my PC over a vonage line whereas the fax machine i had could.
PlatinumGold
23,168
mercanucaribe
Banned
Oct 20, 2004
9,763
Doesn't VOIP use a broadband connection? Why would you want to use dialup? :confused:
Edit: Oh, you want to log in to his ISP.
