If Corolla & Prizm are the same (basically), why do they use different SPARK PLUGS????????????
redgtxdi
5,464
8
NSF4....................this is right up your alley if you're ready........;)
So I go to put in new plugs today & grab some Denso Q16PR U-11's 'cuz that's what Denso says.
Then when I pulled my old plugs I noticed the old ones were......K16R U-11 WTF????
Soooooo..........I look on Denso's site & look up the Corolla (knowing they're the same & figuring that must be the only reason why somebody stuck these in there since they both use the same 4A-FE 1.6L engine) and ***BAM*** there they are. K series instead of Q series.
Now, I understand there are some subtle differences even within the engine compartment....(air cleaner box size for example).....but why in the world would Toyota create the need for 2 different plugs on the EXACT same engine??
Here's a pic for reference..........(I measured 'em both & they'll both reach the exact same depth in the combustion chamber once installed, but the K series core portrudes a little further or you could say the Q series is a little more recessed)..........
Picha, picha
jlee
48,518
223
Either one should work.
Edit: Might want to check the gap on the new plugs..maybe the old one was off, but the two look different in the picture.
redgtxdi
5,464
8
Originally posted by: sniperruff
because one is made in canada and the other one in the US? you think it's a small difference?
Huh??
They were both coming off the same assembly line as I recall. And even if they weren't.............they were STILL both a Toyota 4A-FE motor! Same EXACT motor!
deadlyapp
6,667
742
The gap is different from what I can tell, You sure ones not platinum and one is copper?
redgtxdi
5,464
8
No, both were just regular plain-jane coppers.
The gaps are also the same. The reason they look a little different is 'cuz the old ones electrodes were worn pretty darn well. I don't think they were the originals, but I don't think they were any further than the 2nd set. Pretty old nevertheless.
New electrodes were nice & squared off and just "appear" closer to the ground electrodes.
CocoGdog
848
Actually, even though they are the same motor - Toyota modifies the USA version to run a lot crappier and break down faster.
compuwiz1
Admin Emeritus Elite Member
930
If you're gonna make such a claim, at least provide proof! Sheesh. :p
sniperruff
11,644
Huh??
98 corolla
98 prizm
some corolla's are built in canada and some in US but ALL prizm's are built in the US. i thought ALL corolla's are built in canada...
OutHouse
36,410
616
??? different plugs??? I had a 1995 Geo Prism LSI befor i bought my 04 Camry and when i changed the plugs I just used champion plugs and gapped them to what my Hays (sp) book told me to gap them at.
OutHouse
36,410
616
yea ok dude.
