if all of the world's technological/mechanical knowledge base were wiped out...
maniacalpha1-1
3,562
14
On a related note : If you could go back in time and tell people of all the potential things that could be discovered, and assuming they didn't kill you for being a witch or heretic, how much faster could it all be discovered?
Say, if you could go back to classical Athens or sometime in the Roman Republic.
mmntech
17,501
12
If all modern technology were wiped out, society would collapse. The lack of industrialized agriculture alone would cause massive famines and wipe out a sizable chunk of the population.
JTsyo
11,809
944
Billions would die. Without central control things would just fall into local control. Cities can't support their population without massive food imports. Any area around the city would be swamped with refugees.
Sci-fi book that has this scenario. In the book gun powder stops working too. The first book was good but the rest of the series was meh.
slag
10,473
We would be proper screwed. If this includes power plants, utility providers (water/sewage), ect then we are back in the stone age. Manufactuering is the least of our problems. Getting fresh water, rid of waste, and providing heat/cooling in a day and age that is almost no longer set up for manual methods of that we be seriously up a creek.
Sounds like Mexico.
rudder
19,441
86
most water systems are still reliant at least in part on gravity to feed the neighborhoods, so water would still be available for a time. the hardest part would be fitting wells with wind turbines to bring new water to the systems. im sure there are plenty of people in that industry with the knowledge to make water shortage not such a catastrophe. i would be one of those guys working on getting water to the neighborhoods here.
How soon before all the flushed turds start contaminating the water supply? There will be no one to supply the chemicals to purify waste water. All the dumbasses around will still see that their toilets flush and dump away.
videogames101
6,783
27
A long time, but we do have plenty of knowledge in our heads. I mean, we'd still have knowledge of higher mathematics and sciences, which would make reinventing some of this shit a whole lot easier. The difficult part would be reorganizing society, not reinventing technologies.
hanoverphist
9,867
23
well, fitting wells with wind power could also work with fitting wastewater lift station pumps. the wastewater process is for the most part a natural process, it has been done all over the globe without power. even modern day plants have basic hardware that is being run remotely by sophisticated systems, but have the old manual controls still available. once the electricity portion is solved, its just a matter of switching things at the right time.
and there would still be meltdowns in areas where stupid people do stupid things, that just human nature. i didnt say it would be a perfect situation, but i think it could be handled well over time.
guyver01
22,135
61
what wind power?
what well?
remember? ALL technology is gone.. as is the ability to recreate it.
imagine some type of global disaster struck the earth and wiped out every piece of machinery, documentation (physical and electronic), fabrication/manufacturing plants... all instances wiped out so that we couldn't even reverse engineer anything.
Patranus
9,280
Here is a similar question.
Even with the current knowledge bases, how long would it take for someone to build a microchip without any current tools.
By that I mean starting from scratch knowing what how to get from A-B but not having the tools to do so.
sourceninja
8,805
65
My poop goes into a tank in my backyard, the liquid goes into a field and slowly does whatever the liquid does until its back to clean water.
It's how a septic system works http://www.herchem.com/septic/septicwork.html
JTsyo
11,809
944
they won't. Since it would be circular. You wouldn't be able to produce anything that requires computer to make, which include computers. What people currently know is how to make things with current technology, you would need to find people that know the old school stuff. So start with vacuum tubes and build up. Though I don't know what you would need to build a vacuum tube.
