IEXPLORE caused a general protection fault........
Kelpuk
I keep getting this error whenever i try to browse the web while im using a a filesharing program called Emule. It happens every time i try to browse the web and only while im running that program.
in module LZEXPAND.DLL at 000b:000005cb.
Registers:
EAX=0000ffff CS=1e3f EIP=000005cb EFLGS=00000217
EBX=01610005 SS=5317 ESP=00009eb4 EBP=00009ed0
ECX=0000b2c0 DS=1e1f ESI=00009f22 FS=4627
EDX=0001ffff ES=5317 EDI=00000005 GS=0000
Bytes at CS:EIP:
9a c0 02 27 1e 83 c4 02 89 46 f6 89 56 f8 3d ff
Stack dump:
9f220005 89210005 00ab021f 01770217 02820177 01775700 1e1f0282 001c9eff 00051e87 00059f22 a0fd9ef6 00400005 53179f22 53179f2a 9f220000 9f2a1e1f
Lord Evermore
9,558
emule probably is running tracking software that it didn't tell you about during the install, like many free applications. Lzexpand is used to decompress files compressed by Microsoft's compress.exe utility, which could be anything but may be something like emule trying to make IE load a tracking module, or emule could be interfereing with a normal thing that IE does.
You'll probably be better off posting on the forums at the emule site about this. It is obviously a problem with that software. In fact I just looked and there are several threads about this problem.
