IE7 released!
InlineFive
9,599
Originally posted by: Smilin
Originally posted by: Lemon law
I use firefox and will continue to use firefox---but I am still downloading ie7 even as I type this---because ie is still a necessary evil for things like getting windows XP
updates and such---ie6 is very bad from a security standpoint---and ie7 will be better---but still not up to firefox standards.
And hopefully it will install on my systems without a hitch---I will find out later.---38% downloaded on dial up so far.
What standards are you speaking of? You can disable script execution in IE to make it as "secure" as Firefox. :shocked:
:sun:
Unless you've monkeyed with something script execution shouldn't be running without permissions on IE 6. :confused:
I was speaking of the fact that you can disable ActiveX, Javascript, .NET components, etc. from executing.
Cool, I'm gonna tell my dad to do that. Oh wait, he has no clue what is that.
Exactly why it's off by default. :)
I'm really confused as to what you are talking about. Even with Medium-High (IE7) all of the scripting is still enabled.
Underclocked
Question for those of you running IE7: can you customize the taskbars to same degree as in IE6.xx?
I have IE6 down to one main taskbar and the thinner page title bar. IE7 seems to be far less customizable and creates more wasted window space.
And, briefly running the release last night on another computer with a fresh install, I was getting an awful lot of page cannot be displayed and other errors that didn't occur before installing 7.
Block it from my machine, think I'll wait until they refine it a bit.
Noema
2,974
IE7 Pros:
Loads super-fast
It's sleek looking
I like the RSS integration
Smooth fonts
Cons:
Doesn't have FF's insane number of extensions
No bookmark panel
Sometimes sluggish when viewing sites with lots of flash (which FF handles better I think).
In other words: I like it; I'll be sticking to Firefox but keep it installed just in case :)
Varun
1,161
Originally posted by: MrChad
Originally posted by: Varun
Regedt32.exe
In Windows XP and Windows Server 2003, Regedt32.exe is a small program that just runs Regedit.exe.
I actually don't have Regedit32 on my system even.
They used to be separate programs. If you right-click on the key and go to Permissions, you can add the Administrators group to the keys your having problems with.
Unfortunately I can't. When I right click the key I get "Unable to open key" and there is no way for me to set the permissions.
Smilin
7,357
:sun:
Likely source of confusion: medium settings stuff can run without prompting once it is downloaded. Getting it downloaded is where all the prompts come in.
Medium settings:
download signed activeX controls: prompt.
unsigned: disable
don't confuse with other settings such as:
Run activeX controls and plug-ins: Enable.
Again, this allows controls to work if they have been previously downloaded using the aformentioned restrictions (stops you from getting hammered for a prompt EVERY time...but doesn't actually allow something to run without a prompt).
The setting that catches everything else:
launching applications and unsafe files: prompt
Once you approve something the remaining 'medium' settings let it run (.net components, java etc) without further continuous prompting.
You can of course crank up to high and probably drive yourself insane but medium+some common sense will keep you (and dad) out of trouble. Server 2003 browser settings are wicked locked.
boy, this quote got deep!
Smilin
7,357
Regedt32.exe
Symptoms of registry damage or a root kit.
InlineFive
9,599
:sun:
Medium settings:
unsigned: disable
Oh, I see what you are talking about. Thank you. :)
Varun
1,161
Regedt32.exe
I got it installed today by unchecking the "Install necessary updates and ..." box. Wierd
Brazen
4,259
:sun:
Install Firefox with the NoScript plugin. The NoScript plugin causes promting for EVERY script that runs on a webpage. You'd be amazed at how much gets by IE.
Robor
Originally posted by: Brazen
Already?! Ach, I'm going to have to go block it on our WSUS server!
Doesn't WSUS make you approve the new updates before they're installed? When I get new updates on my WSUS server they're all set to 'detect only'. If I want the new updates installed I have to to approve them and set the appropriate groups to 'install' or 'detect only'.
stevty2889
7,036
8
Well I've given up on it. I tried for a 3rd time. Still crashes immediatly upon opening. Event viewer errors:
Fault bucket 337279712.
Faulting application iexplore.exe, version 7.0.5730.11, faulting module unknown, version 0.0.0.0, fault address 0x00000000.
Faulting application iexplore.exe, version 7.0.5730.11, faulting module ieframe.dll, version 7.0.5730.11, fault address 0x000bbaa7.
stash
5,468
That's correct, you will need to approve the update before it goes out. The blocking kit for IE7 is mainly for those orgs who do not use some sort of managed update service, and just let their clients use either WU or AU.
And even in the case of AU, it will not auto install because the user has to accept the EULA.
InlineFive
9,599
:sun:
I bet but fortunately for me I'm not that paranoid. :p
wiin
937
Originally posted by: stevty2889
Installed and unistalled. After installing I could no longer connect to my own wireless network. I managed to connect to a differant one by IE7 crashed immediatly upon opening it. Uninstalled it and everything is back to working normaly. Anyone else try it yet?
Been using IE7 with Vista Beta, then upgraded to Vita RC1.No problem at all
dennilfloss
Past Lifer 1957-2014 In Memoriam
Oct 21, 1999
30,509
12
dennilfloss.blogspot.com
Just installed it after making an image of my OS partition just in case. No problem so far. I am disappointed at the inability to move/disable/compact many bars in IE7 but that's not too bad as I use AvantBrowser as my default browser. Someone at Ars said the lack of customization of the tool bars compared to IE6 is suppose to provide higher security from malware changing your settings.
cutty
311
I installed IE7 and I can't connect to any website now!
I have installed last Beta release and it works fine, I have no idea why it doesn't work now.
My system is Dell 600m. I know my network is ok, I tried all other programs such as Firefox, putty, ping etc, there is no problem at all. However I can't connect any website with IE7! I checked Connection setting, nothing is checked and that's what it should be. I really have no clue now. Could any one help? Thank you.
theheartofwinter
15
So is it worth it to upgrade to IE7? Still using IE6 at office and Firefox at home. Would there be a new Firefox release also?
Brazen
4,259
firefox 2.0 was just released
InlineFive
9,599
You should still upgrade to IE7 because of less vulnerabilities than compared to IE6.
If you still want to use Firefox as your daily driver be my guest.
nweaver
6,813
are there any compelling reasons (i.e. innovative features) to switch from a non IE browser?
InlineFive
9,599
There is nothing that hasn't been done before for the end user. Most of the changes (in my mind) are the backend for administrative purposes.
That being said I still hold that you should install it for security reasons. Even if you primarily use/like Firefox, Opera, etc. more.
Smilin
7,357
:sun:
That is not at all an apples to apples comparison.
You are talking about *altering* the default config of firefox then comparing it to the *non altered* default config of IE.
Go flip security on IE to high and see what happens. Also see previous explanation of why IE doesn't prompt every time. Here's the short version, "It would drive the user mad without adding extra security."
Hadsus
1,135
CNET has a review up posted October 18:
http://reviews.cnet.com/Internet_Explorer_7/4505-3514_7-32111537.html
Final score = 7.0 of 10.
The good: IE 7 includes built-in tabbed browsing; antiphishing technology; an RSS reader; and a redesigned Favorites Center.
The bad: IE 7 is limited to Windows XP SP2 users only; installation requires reboot; reuses old IE 6 code and doesn't yet comply with current Web standards; doesn't match all the features found in Firefox or Opera; carries a Microsoft legacy of not patching its IE flaws quickly enough.
The bottom line: IE 7 was Microsoft's one chance to leapfrog ahead of the competition, but the company has only barely caught sight of the current front-runners. For more features and greater security, switch to Mozilla Firefox.
