IE6b 2479 having java problems?
dowxp
for some reason, its giving errors on sites which i know dont have errors. for example, on windows update, i try to go to product updates, it says:
"object doesnt support this property or method: 'document:rookie'"
other reputable sites like download.com have java problems. i thought it was my JVM, but download.com says to update to sp2. which i have.. any ideas?
I am using 2479 and I dont find the java problems. Could you post some problematic sites so that I can test test. However, I dont have any problem viewing cnet sites as well as windowsupdates.
Might wana try uninstall and reinstall IE6 again 🙂
