IE6, small forum icons not displaying
ArmchairAthlete
This problem has been around for awhile, I'm not sure what causes it or how to solve it. Sometimes small icons on forums do not show. Usually the ones that tell you about post, the envelope that shows if it is a new post, if you have participated in it, etc.
Screenshot:
http://members.cox.net/armchair-athlete/forumproblem.jpg
It occurs on other forums as well, and occasionally on some web pages small images won't load.
Right clicking and selecting "Show Image" will get the images to show up properly.
Powercolor Radeon 9700 Pro
AMD Athlon 1700+ Thoroughbred-A (OCed to 2400+ or greater, 190Mhz x11)
Asus A7N8X Deluxe Motherboard (nForce2 Chipset)
512MB Corsair XMS DDR400/pc3200 (2x 256mb sticks) CL2
Windows 2000 Professional SP4
IE 6 SP1
Western Digital WD800BBRTL 7200RPM 80GB Hard Drive
had the same issue, fixed it when I reformatted...
Though I would check your Receive Buffer and MTU settings.
For grins, try this.
Start--> Run--> REGEDIT
Go to File--> Export --> and save a backup of your registry somewhere in case you need to IMPORT it back.
Now find the key \HKey_Local_Mcahine\SOFTWARE\Classes\PROTOCOLS\Name-Space Handler\
Delete any folder under that heading except for MK (possibilities are HTTP, HTTPS, and FTP).
Now find the key \HKEY_CLASSES_ROOT\PROTOCOLS\Name-Space Handler\
Delete the same things if they exist (making sure to keep MK).
Close REGEDIT, reboot, and see if it happens again.
deadseasquirrel
Thanks deadsea.
I want a browser that displays ALL pages correctly (now that it is fixed =P). I've heard too many complaints about pages loading messed up or not at all with other browsers, so no thx.
IE6 + a handful of choice plugins for me.
