IE Proxy Help Requested?
RobDMB
434
The school I attend requires a proxy to access their wireless network while at school. Normally whenever I go to school I have to go to Internet Options -->Lan Settings and then check the box that says use a proxy server for your lan. Then when I come home at night I have to uncheck the box to use the internet at my house without the proxy. I am wondering if there is anyway that IE can autodetect a proxy server so i don't have to constantly check or uncheck that box to enable or disable the proxy. Any help is appreciated. -Rob
spidey07
65,469
not really. there is an auto-detect proxy settings but that has to be provided by the DHCP server and it is rarely used.
I'm sure there are programs out there that will do this for you by running them and they make the change. something along the lines of "if I don't hear back from my proxy server then remove it"
nweaver
6,813
never checked, but if netsh can enable/disable this, then write a couple of scripts and drop them in quicklaunch or start menu.
skyking
22,714
5,842
I have some scripts a buddy wrote, I will ask him if they are open source and post:)
skyking
22,714
5,842
A very big Your Mileage May Vary warning:;
ProxyOff.js
---------------------snip-----------------------------------
// JScript.
Sh = new ActiveXObject("WScript.Shell");
key = "HKEY_CURRENT_USER\\"
Sh.RegWrite( key +
"Software\\Microsoft\\Windows\\CurrentVersion\\Internet
Settings\\ProxyEnable", "0" , "REG_DWORD");
//Sh.RegWrite( key +
Settings\\ProxyServer","", "REG_SZ");
WScript.Echo( Sh.RegRead(key +
Settings\\ProxyEnable"));
//WScript.Echo ( Sh.RegRead(key +
Settings\\ProxyServer"));
key = "HKEY_CURRENT_CONFIG\\"
Sh.RegWrite( key +
"Software\\Microsoft\\windows\\CurrentVersion\\Internet
Settings\\ProxyEnable", "0", "REG_DWORD");
----------------------------------------------snip-------------------------------------------------
ProxyOn.js
---------------------------------------------snip----------------------------------------------------
// JScript.
Sh.RegWrite( key +
Settings\\ProxyEnable", "1" , "REG_DWORD");
Settings\\ProxyServer","12.229.56.110:2050",
"REG_SZ");
Sh.RegWrite( key +
Settings\\ProxyEnable", "1", "REG_DWORD");
-----------------------------------------------------snip---------------------------------------------
work.bat
------------------------------------------------------snip-------------------------------------------
@echo off
ipconfig /release
ipconfig /renew
cscript ProxyOn.js
Make those files and put them on your desktop in a
folder or whatever.
They need to be in the same folder.
This has been tested on MS campus with XP Pro,
ymmv:)
nweaver
6,813
my gut instict is to puke when I see java doing system scripts.....but I'm not a big java fan, /shrug
kamper
5,513
Fortunately, that's not java ;)
kamper
5,513
Sure javascript, but it's not java. A linguistic technicality maybe, but there's a huge difference in the real world (the two share absolutely nothing in common). I would really understand your distate of system scripts written in java :)
But what's so bad about javascript? It's nothing more than a syntax convention and it's not like it's the same stuff that's running in your browser. If you don't like the syntax or the oo model then sure...
nweaver
6,813
I'm a perl guy, and a little bit of Bash
I've even dabbled int netsh, but only enough to write perl scripts that dump data to netsh batch files to do stuff MS didn't provide a way for, like loading DHCP reservations from a CSV (or any format other then a backup from another windows server)
