IE and Ping ect not working
lucrioual
111
Alright, so multiple people use the computer I'm on and what happened was someone downloaded something that installed a browswer hijacker and search toolbar. So I searched around for the toolbar ect that was installed and found a nice little program called HijackThis, which very efficiently removed the toolbar. But what happened after that was IE stopped being able to connect to websites. Later on I went to ping a site and that wouldn't work either, nor tracert. I tried to reinstall tcp/ip by deleteing winsock and winsock 2 and stilll had no luck.
I am running windows xp and mozilla so it isn't realy that big of a problem but i would like to be able to ping and what not
thanks
drag
8,708
In order to reinstall TCP/IP under Winxp (and w2k) you have to do a "reset"
from the command line go:
netsh int ip reset c:\resetlog.txt
then you can examine the resetlog.txt if you want for details.
If that doesn't work then delete all your network connections, uninstall the network drivers, and then re-setup your network connections. That should get it going.
The ping issue maybe caused by a third party firewall. Turn that off and see if that fixes that.
Your can do a repair of Internet Explorer + affiliated programs (outlook express) by acting as if your going to uninistall internet explorer from the control panel, as you do that it will ask if you want to do a repair. Say yes.
Or
You can head on out to microsoft's website and download the latest IE download and install that, it will effectively do the same thing.
Eltano1
1,897
Schadenfroh, that is a great program, it help me to fix one of my customer's PC when I removed AOL 9.0 (what a pain in the a$$).
best regards
eltano
