hello
ive got AXP PALOMINO 1800+, volcano9 HSF, and using artic silver 3 as TIM.... 3 92mm intake fans-1 infront blowing in & 2 at the bottom side panel, 2 80mm exhaust fans at the back near the CPU & my PSU is a double fan with a 92mm fan sucking air from the inside casing to the psu & then to its 80mm exhaust fan of PSU........ if my temp sensors are accurate, my cpu temp is 43-44degC at idle & case temp at 31 degC... at full load, im able to have 47-48 as cpu temps..
my question is has any1 have almost the same setup as mine? i just wanna know how people are able to lower down thier idle temp to below 40degC while just using air cooling? what are you idle temps (no software cooling used, okey? 😉 )???
pls give advise in how to lower down temps, especially at idle....
thanks & happy cooling to everyone!!!!
