MrChipMuthabored
What should your CPU usage be when its idle? Around maybe, 0-10%, right? Well mine spikes up to 50% when idle. What the heck is going on? I've got nothing running (explorer and systray only), so why would the cpu be working so hard? The cpu used to hit 100% at times and give me an hourglass, but every since I defragged, it went down, but still, 50% cpu usage at idle is pretty weird. I also changed my swap file (virtual memory) settings so that they are static, and so the CPU won't have to re-size them.
Check out my system specs below!
Thanks!
Thanks!
