Ideas on how to heat a Kidie pool needed. Sorry for quad post will keep this one
AnMig
1,760
I am sort of desperate.
I bought one of those easy pools 12 diameter X 32 height.
It took 5-6 hours to fill up and my water heater is not able to keep up. (1700 gallons)
I bought one of those bucket heaters 1500 watts and left it submerged for 24 hours but it did not even budge the freezing water.
As you might imagine the kids are getting very agitated waiting to jump in the pool for the past 48 hours.
I live in rural minnesota and the temp still goes down at night.
I need ideas on how to heat this pool aside from leavingit under the sun.
I was thinking of buying one of those water heating elements 5000 watts and diong a Macgyver thing but my kids get electrocuted
suggestions needed.
I searched all over and could not find a portable water heater to met my needs
peace
AnMig
1,760
god dam quadraple post sorry guys
I must have hit enter couple of times
I blame my modem connection:)
help still needed
Fausto
26,521
Originally posted by: notfred
put it in the sun for an hour.
Floating some black trash bags on the water might help heat it quicker if you take the solar approach.
Woodchuck2000
1,632
Either make good use of your kettle and mix boiling water with the tap water, or try and get hold of an immersion heater... How big is the pool?
AnMig
1,760
Thanks for suggestion woodchuck
An immersion heater was what I tried, the only one I can find locally is a bucket heater (1500 watts) but it did not even budge the pool temp even after 24 hours. (returned it)
the only other available immersion heaters are those de-icer things (used for lives stock) but I dont think those thing heat just de-ice
anybody know of a stronger immersion heater?
