Idea - "Ryzen VGA card".
VirtualLarry
56,587
10,225
It has come up again and again, that AMD is not competitive at the low end or in business machines, with Ryzen, because no iGPU.
I know that Ryzen Mobile is coming out, and there have been waffelings about possibly not being released for Desktop?
Either way, a great way to move Ryzen CPUs, including the Ryzen 2000-series CPUs (Zen+), without an iGPU, would be to release a really cut-down RX 550 card, call it the RX 540 or 530, with half-again as many shaders (one fourth of the total shaders of the chip in RX 560), and possibly even GDDR3 or DDR3, if the GPU even has memory bus connections for older DRAM standards, but including support for 4K UHD video desktop output, and video-decoding support. Basically, a 4K-capable HTPC-style card. Make it passive, like the NV GT1030 card. Release it cheap, and make it a bundle, or offer a combo rebate, if you buy a Ryzen CPU with it.
That would go a long way towards ameliorating the difference in price and functionality, between Ryzen and Coffee Lake, for entry-level and business-class builds.
jpiniero
17,112
7,498
They do... the 520 and 530 is Oland though. Which is 5 years old. Although I think there's a second version of the 530 which may be a bit more recent gen but for sure is 28 nm. I don't think AMD wants to spend the money to do another mask for something that small.
VirtualLarry
56,587
10,225
"Oland"? You mean the GPU in the R5 230 and 6450? That's not even GCN, is it?
I wasn't talking about needing another die spin, just a means for them to dispose of heavily-damaged RX 460/560 dies.
cbn
12,968
221
I'm thinking Polaris 12 (512sp) probably does have a DDR4 memory controller on it. It is the only reason I can think of why it has 128 bit bus like the 1024sp Polaris 11 used in the RX560.
P.S. From an older post I did calculate a cutdown Polaris 12 with DDR4 2400 would have a similar core to memory bandwidth ratio as RX 560:
It could even be DDR4 and a cut down version of Polaris 12. (re: 384sp @ DDR4 2400 actually has a similar core to memory bandwidth ratio as RX 560).
VirtualLarry
56,587
10,225
Is there even a Polaris 12 chip? I thought that RX 550 (512 SP) was just a binned / disabled RX 560 GPU chip (Polaris 11?)
cbn
12,968
221
VirtualLarry
56,587
10,225
Thanks, cbn, I didn't realize that the RX 550 had it's own Polaris 12 die for 8 CUs. So if it does, and AMD doesn't sell anything with less CUs, then maybe they should... introduce an RX 540, with 256 shaders, and maybe 64-bit GDDR5, and especially, WITH the updated video-decode support, make it passively-cooled, and sell it for $50. Would make a nice Ryzen CPU compliment, for those rigs that need video-output and HDMI2.0 and video-decode support for 4K VP9 for YouTube.
mikeymikec
21,412
16,622
Is there a good explanation somewhere of what GCN does (at a "this is how it helps end users" level)? Wikipedia isn't much help.
VirtualLarry
56,587
10,225
It's not directly so much of "how it helps end-users", so much as it is, GCN and derivatives are the only currently driver-supported architectures by AMD. If you buy a VLIW4/5 GPU ("Terascale"), then there are no new drivers for those cards. So it's really GCN or bust, if you want to be supported. Well, that and Vega, but Vega's not fully-supported (yet) either.
VirtualLarry
56,587
10,225
mikeymikec
21,412
16,622
Ah, I see. Thanks.
VirtualLarry
56,587
10,225
Someone posted in Hot Deals about the flood of Zotac GT 730 1GB GDDR5 PCI-E x16 video cards, for roughly $40 ea. HDMI/DVI/VGA. ITX-style, but with fan, not passive.
Seems ok to me, I bought some for my Ryzen builds
IntelUser2000
8,686
3,787
The low end, especially if they want to fulfill what you are suggesting, is quite high volume, so not only they'd have to re-salvage such throwaway dies but may have to purposely cripple good ones as well.
Also the fixed function and media units don't change in size, so as the chip size becomes smaller, the more sacrifice they have to make to reduce the size. Nothing beats integration for low cost machines.
