- May 6, 2002
- 91
- 0
- 0
I have a new idea for a quiet power supply that one might buy from Zalman. It is quiet without having very poor airflow. Imagine an Enermax dual-fan power supply, but replacing the rear fan with just some vents and without the front vents, so the 92mm fan on the bottom is forcing air over the PSU's heatsink and directly out the back. Then the 92mm fan could be thermally-controlled, and a quiet one could be used, so that the net result is a single-fan power supply with higher potential airflow than most single 80mm designs. There could be a single row of vents on the front that allow air to re-enter the case, just to add airflow. Then the fan would be mounted with rubber grommets, isolated from the housing.
What do you think about my idea for an improved ATX power supply?
