Hi, Jiggy has the right Idea. Forty pin and wire cables must use Master/Slave settings. Newer, usually 40 pin/80 wire cables are usually CABLE SELECT (CS). They will have color coded connectors. They must be set with both drives on the cable to CS. Position on the cable determines which is C: and which is D: etc. Good Luck, Jim
