Just put a new system together and it has 3 IDE drives in it and a SATA system drive.
No matter what I try I can only get 2 of the IDE drives to work at the same time. All work fine but as soon as I try to boot with all 3 the PC locks at the bios screen. And it doesn't matter if they are split on 2 cables or on one, only 2 work at once.
I remember seeing this problem on a friend's PC a few months ago and it took us a while to figure it out but i think it had something to do with raid drivers.
So any suggestions or tips on how to get this working?
Currently Running
XP SP2
AMD Athlon 64 3800+ Orleans 2.4GHz Socket AM2
ASUS M2NPV-VM Socket AM2 NVIDIA GeForce 6150 Micro ATX AMD Motherboard
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800
eVGA 256-P2-N554-AX Geforce 7600GT 256MB GDDR3 PCI Express x16
System Drive
Western Digital Caviar SE WD800JD 80GB 7200 RPM SATA 3.0Gb/s
Storage Drives
250 Seagate
250 Hitachi
320 WD
Thanks for the help
Currently Running
XP SP2
System Drive
Storage Drives
250 Seagate
250 Hitachi
320 WD
Thanks for the help
