imported_KuJaX
I have a dilema,
I just got done building a system of which the mobo only had one IDE port. Well, there is the DVD burner and harddrive. I didn't even think about checking to see if the mobo had two IDE ports as i just figured it was pretty standard (of hundreds of systems i've built, i've never played with a mobo that only had one IDE port).
Regardless, the IDE cord that was sent with the mobo is 18". I do have a rounded cable sitting around that is also 18". Now, the issue is not from the motherboard to one of the devices. The problem lies in the legth from DVD burner to harddrive IDE length.
So to my question: Is the 36" IDE cable found on retailers like Newegg have the same length from DVD burner to Harddrive, or is the extra length pretty much found from the mobo to devices?
Any help would be greatly appreciated.
