I need an 80 pin IDE cable. From what I remember in the past with random cables I had around, I had a hard time find one that would fit properly. They have that bar that passes over the top of the cable where it attaches to the connector. This forces the cable to be bent over in a certain direction. In the past I found that this caused the cable to have to be twisted in order to be able to reach the drive and would cause a problem routing to a slave.
Is the direction of the cable supposed to be standardized? So that if I order one online I will know I'm getting the right one.
Local office stores don't even have them. All compusa had where the expensive round style. We have a microcenter, but it's far and they are usually pricey. Where do you guys get them locally? And if not where is a good place online and a typical price? I'm thinking maybe ebay.
Thanks for taking the time to read and help out, much appreciated.
