Installed my old AOpen i855GMEm-LFS into a brand new In-Win Mt. Jade case. It was a nice fit, and it actually worked fine for a few days. Until I shut down the system for the first time (as opposed to S3 Standby).
Next morning it refused to turn on. Looked like circuit protection was going off. Fans were spinning for 1/2 a second then stopped. I narrowed down the problem to the front-panel USB headers. With these unplugged the system booted just fine. Disconnected the USB cables at front-panel side and decided to test at with just USB cables plugged in - everything was fine. Connected the front panel again, pressed Power, the system turns on (hot start?). A second later I hear three quiet pops and feel a burning smell. Investigation showed I now have a small brown hole in my ICH4 chip. Motherboard is dead.
First thoughts - a short-circuit in the USB ports, although I never even touched them and everyone in the household swears the same. Upon testing the front panel pins with a multimeter I couldn't find anything wrong with them. Visual and olfactory inspection revealed nothing. The only weird thing I could find were the 100uF caps between the USB +5V and GND leads. Could these be the culprit?
Should I take this issue up to the computer case retailer/manufacturer? I guess it will be very hard to make either of them reimburse me for the damaged motherboard?
