iCage help plx
brock01
105
Hello
hopefully you guys can save my life with this iCage i just bought
so i have this http://www.newegg.com/Product/Product.asp?Item=N82E16811133154 case and i bought the icage, and i would like to know how you install the icage right above the factory one? i just can seem to figure it out. how do you remove the floppy drive bay thing? its in the way, and dont know how to take it out ( if thats even needed to be able to install)
thanks in advance.
Brock
brock01
105
ah too bad it dont say to remove side of it...
dont really care no more, since i got it now
