- Feb 4, 2004
- 334
- 0
- 0
I am confused and can't seem to find out on my own if the standard RJ45 ethernet cable would be compatible with the integrated internet slot on the IC7-MAX3. The slot looks different than a standard RH45 slot. Do I need a new cable/ router for this slot?
Here is a picture of the IC7-MAX3's back panel:
Back Panel
Here is a comparison of the 2 I am talking about on a different motherboard(used for reference):
Back Panel of different Mobo with both slots
->Look carefully
Please help, I want to get the MAX3 but I don't know if the slot is compatible.
Back Panel
->Look carefully
