IBM X40 - Problems after installing WinXP SP2
venom600
395
Hi I just recently installed SP2 into my computer and I lost some functions for the Fn key.
Nope not the curse word, for example (Fn + F5) its suppose to turn on my wireless modem but it doesn't do that any more.
Also turning off my screen doesn't work any more.
I have looked all over my control panel and can't find where to set them up again.
If anyone else knows how to turn back this function for the laptop please help me out.
Thanks,
venom600
venom600
395
i'm not sure what you mean by event viewer.
If thats in your control panel, its not in mine.
n0cmonkey
42,936
It's under administrative tools or something like that. It's what you look at to see the logs on your system...
venom600
395
I just took a look and i don't think thats the right place to go.
I think its something simplier.
These are just hot keys by the way.
Something like you could set up like Ctrl + Alt + F3 will open up Photoshop or go to a home page.
n0cmonkey
42,936
I know what you're talking about. I was wondering if there was something in the logs that might have told you if a driver or something failed to load. But whatever. Good luck.
