IBM Deskstar 75GXP & K7T Pro 2-A problem
dakankm
13
Hello
I have encountered a problem with installing an IBM Deskstar 75GXP 20GB hard drive on to K7T Pro 2-A motherboard. Hard drive detected fine, first part of Win2K installation passed fine but second failed with a blue screen saying ?Hardware Failure?. Hard drive fitness test by IBM passed fine. So I have no clue what the problem is? I have another hard drive that works fine.
Any help would be greatly appreciated.
Thank you
Max
KevinH
3,110
7
Give us more info man. What do you have in your system, etc. Bios veresion, cpu temps. Could be anything, for instance, I had a problem installing win98SE. Went throu 99% of the way then I'd get the BSOD. Tried a different disk and it worked perfect. Strangely enough, the disk I was originally using never had a problem before. Go figure.
Snoop
1,424
I had a friend with a 2a that was getting the Hardware Failure message when installing 2000, bios update from 2.2-2.4 solved it.
Hope this helps :)
dakankm
13
The system is:
K7T PRO 2-A
Duron 750
128MB RAM Mushkin PC133 SDRAM
Stealth III S540 Xtreme AGP
NetGear Network Card
On bouard audio
BIOS flashed to 2.4
Thank you
Max
