IBM 75GXP 45 gig hard drive problem
moemac8
147
It seems my HD spins alot, even when nothing is going on. Even after a reformat and install of Windows XP. Is this one of the IBM drives that was supposed to have problems. What exactly were the problems and what can I do to fix it. I downloaded IBM Disc Fitness Test and booted to it ran it and it found bad sectors and wanted to erase the disc or repiar the bad sectors. I let it repair the bad sectors but it always hangs after a certain point and will never finish.
Also I have two HDs each with two partitions, how do I tell which drive letter is on what actual HD.
Budman
You cant repair bad sectors, bad sectors are BAD for life & you'll need to replace the hd.
Frankly it's a miracle that hd lasted this long !! :)
Wiktor
151
Very good article there on anandtech, wasn't there when I last researched the issue (I have a 60GXP, so it concerns me too :().
moemac8
147
I think I just toss it and get me a Serial ATA HD, my new motherboard (Abit IS7-E) has it but I didnt want to buy a new drive
Swanny
7,456
RMA it if you still have warrenty left. The last one I sent in came back with a 120GXP as a replacement, which doesn't have the same problems.
ssanches
461
Originally posted by: lnguyen
my friend sent a 75GB in... came back as a 180GXP... VERY quiet...
If you enjoy a quiet IBM HDD then you may have my dead 75GXP that's very very silent. Frankly I haven't heard it make any noise for the last couple years
Heck it's quieter than my Barracuda IV 40GB ST340016A
Deskstar
1,254
One of mine failed and I got a new one promptly from Hitachi under warranty. Then I tested my other four and found one was going bad, but more than 3 years old. Two failures out of 6 drives in 4 years.
gatewaysrule
How did you get that thing to last this long?! I have went through about 4 IBM death star hard drives already in one machine! Sounds like you're going to have to RMA it.
Insane3D
19,446
Actually, you can if it is not a physical problem on the drives data area. I used to have a 75GXP that woul occasionally develop bad sectors, and a low level format fixed it up.
Mavrick007
3,198
Heh Budman, my old 75GXP 46.1gig is still going strong. It's used as the main drive too. I should probably be quiet cause I'm sure the 3yr warranty is up by now.
*knocking on wood*
Also, I would suggest doing a low level format to see if it can fix the bad sectors. It just might do the trick.
Whitneymuse
353
I kept hearing about the 75GXP and the class action law suit, blah blah blah. It was a YMMV thing, until about a year and 1/2 into my usage, I heard the so-called IBM "scratch of death". In fact, someone posted a .mp3 file that sounded like someone taking sometihng metal and periodically bringing it down on a metal turntable, lifting it, then laying back on the turntable. Couldn't repair, couldn't reboot it, could RMA it.
December 2002, got a brand new 60GB 180GXP in return for the 45GB and then IBM ((((poof)))) went out of the hard drive business. It's fine so far, very quiet AND, I don't use it; it's in it's anti-static bag and I use it exclusively to backup WD SE drives and Maxtor 8M cache drives.
That said, all drives have a history of problems. SReview has an ongoing survey of users' experience with drive manufacturers and all of them have problems. So, make certain to either go to a RAID and/or back up images of everything.
