i9-9900k and Ideal CPU Cooling/Case Combo
Dave3000
868
I've been thinking about upgrading to an i9-9900k, MSI Z390 Gaming Plus, 32GB Crucial Ballistix Sport LT DD4-2666, and I'm still undecided about which case and CPU cooler to get. I really don't want a bulky case. I want something smaller than my CM690 II case. I also understand the the 9900k has a 3.6GHz base clock and a 4.7GHz all-core turbo clock and I would like to have sufficient enough cooling to prevent it from throttling during CPU stress tests. What would be an ideal CPU cooling/case that will keep it at 4.7GHz all-core turbo without throttling for this CPU in CPU stress tests?
Apr 27, 2000
11,018
642
You might want to try the Cases&Cooling section for that.
Apr 27, 2000
11,018
642
Hey! Somebody moved your thread. Mighty nice of em. So let's see.
I highly recommend an AiO for a 9900k. There are a number of them that will work for one running at "stock", which for a 9900k sort of varies based on which board you use. You should expect to treat it as a 160W CPU unless you wind up with a board that implements PL2 limits @ stock (then it can be 210W) or unless you tweak your settings to force it into a 95W power limit. Regardless, there are a number of AiOs that can handle the load.
One I would look at would be the EVGA CLC 280. It's not that expensive, and it stacks up pretty well against more-expensive AiOs with 360mm rads.
From there, pick a case someplace like pcpartpicker based on this system build stub:
https://pcpartpicker.com/list/VHRChy
If you really want something smaller than your CM case, you may want to switch to an mATX board.
aigomorla
Cases and Cooling Mod PC Gaming Mod Elite Member
17,173
52
that is a full size ATX board, so your choices in small cases are going to be limited.
typically if someone wants to shrink there system, they would go mATX especially on a cpu which can not even support that many pci-e slots with full lanes.
And yes its going to be very difficult to find a case smaller then your 690 II.
Campy
620
14
Define C/Meshify C fit the bill of smaller case pretty well, and have some decent options for cooling aswell.
Mar 7, 2019
45
8
11
#6
i9 9900K
Corsair H115i Pro with 2 ML140 Fans
Corsair 760T
5.0 GHz OC
-2 AVX Offset
Lower 80's in Aida 64 Stress test. But it all depends, I could test 10 9900's and have 10 different results.
Similar threads
ASK THE COMMUNITY
TRENDING THREADS
