Question i9-13900K or i9-12900K for EVGA Z690 DARK K|NGP|N
GEOrifle
833
15
Hi. I'm waiting for EVGA Z690 DARK K|NGP|N motherboard from EVGA RMA.
Latest BIOS allowed board accept beside 12th generation CPU's also 13th generation(some even have 14th installed with custom BIOS).
So question is which CPU i should go, for i9-13900K(fast and hot) or i9-12900K(slover but cooler and cheaper).
I know it's already old board with z690 support when new ones are already selling(curently got LGA 1851 Ulrta 265K build 3 months ago, also have some old ones too, nothing emergency).
Maybe isn't worth it (even board is high standart) to keep it because old generation, sell it and spend for LGA 1851upgrades ?
Some recommending keep EVGA Z690 DARK K|NGP|N because it's high value and invest into it.
Thanks.
alcoholbob
6,390
469
Why specifically 12900K and 13900K? Do you already have these CPUs? If so update the BIOS, do a -75mv to -100mv undervolt (or further if your chip can handle it) and the 13900K should be perfectly fine. At Intel defaults the PL1 is 125W for Raptor Lake, so for gaming and sustained productivity it doesn't really run that hot at all, in fact it runs cooler than Arrow Lake at the same TDP as it's less power dense. It's only a problem if you run the CPU at unlimited power settings and stock voltages, which are frankly, insane.
If you are gaming, there is no point for any 1851 upgrades, Arrow Lake isn't any faster than a 12900K in gaming, and it's also a dead end platform.
GEOrifle
833
15
I'm trying to get one before board arrives.
Did Intel fixed 13900K problems? Maybe more stable 12900k is safer?
From other side 12900k supports only lover end DDR5
coercitiv
7,449
17,762
They say they did, but even this month they released a new firmware that is suposed to further limit degradation:
If your system is just for fun and games, go with 13900K. If the system is also occasionally used for other activities (work, personal data & finances etc) then go with 12900K.
Reactions: DAPUNISHER
Sgraffite
204
141
If the motherboard is high value, does that mean you can sell it for high value? Or it will be high value in the future for some reason? It seems like it would be a liability over time and not an asset, so given the opportunity to cash out it might make sense.
ValidUsername
18
18
If it's high value, it probably means the opposite. I could see that logic for limited editions, but again, we're talking about motherboards here.
Maybe something like EVGA's SR series, sure, but anything else, hardly worth considering as an investment. LEGO's arebetter for that :sweatsmile:
aigomorla
21,118
3,644
Thanks.
without knowing what exactly the you need the system for, its like saying, that 67 corvette is a excellent value, and everyone recommends me holding onto it, even tho you need might need a pickup for day to day stuff. And well, i can pretty much gaurentee if u tried to use a 67 vette as a pickup truck, you will get dragged out into the street and most likely shot, then revived, and shot again some more.
Meaning that platform is a great for overclocking and gaming, but if it comes to productivity, it will get flat ironed by most of the zen6 cpu's in top tier gaming by a X3D, and productivity on a Ryzen 9.
But if u dont need that much prowess, then yeah, its a good value to invest, but invest and PC's don't go well together, as they devalue about as fast as cars do, unless you got that special chip.
Reactions: Thunder 57
Ranulf
2,902
2,570
I would go with a 12900k and completely avoid 13th/14th gen unless you feel daring and you get it dirt dirt cheap. As in, free.
Reactions: Thibsie
