Hi
I think my cpu temps seem too high for my water cooling setup, so I would like an opinion on whether or not my suspicion is correct.
Thanks.
Temps @ ~25 °C (77 °F) ambient:
Idle: ~50 °C (122 °F)
Load: ~75 °C (167 °F)
System info:
i7 920 D0 4,2 GHz @ 1.4125 V (Vdroop is enabled so the voltage is a bit lower)
Asrock X58 Deluxe3
3x 2GB 1600 MHz RAM
3x GTX 280
Corsair 850 W PSU
Water cooling:
Waterblock: Swiftech Apogee GTZ (AS5 thermal compound used)
Radiator: XSPC RS360, 3 fans in push, 2 in pull configuration (all with decent cfm value)
Pump/Reservoir: XSPC 750 Dual bay Reservoir w. pump (750 L/h)
Thanks.
System info:
Asrock X58 Deluxe3
3x 2GB 1600 MHz RAM
3x GTX 280
Corsair 850 W PSU
Water cooling:
