i7 or i5 for Virtual Machines
stargazr
4,268
3,881
The i5 should be plenty. If this is a new build you should look at the new Sandy Bridge Intel CPU i5-2500K.
nanaki333
3,772
13
for desktops and even servers that will host active VMs, i go with AMD based processors. more cores for less money and just allocate entire cores to the VMs. my exchange server is a dual 8 core with 4 cores for each of the roles in hyper-V's. my desktop PC is a 1055 so i can just leave do whatever i want on the VMs and not worry about things getting choked up on my main drive and have free cores and memory :)
t0m3k51
45
If I decide to go with AMD-based board, will I be able to run Mac OS X in a virtual machine?
Makaveli
5,026
1,624
Are you planning on putting an SSD in there, i've heard that VM's on SSD's are en excellent combination.
amenx
4,721
3,012
Guest VMs on VirtualBox v4.0 are so fast on regular HDs they already feel like on SSD.
nyker96
5,630
really? I'm using VMware and it feels much slower than regular HD access, not even going to bother comparing the VM HDs to an SSD. What medicine does Vbox has that VMware doesn't to make the virtual HD that much faster?
flexcore
193
If you go with AMD get yourself a good 890FX board with x6. The 890FX has IOMMU support whereas the rest do not. Allows hardware direct access to vms. Googlefoo will go along way to help you make a good decision.
iluvdeal
1,975
Have you tried the option to preallocate disk space to a VM in VMware? That is suppose to improve performance a bit, I haven't tried it yet though.
