Computer will be used mostly for gaming and the usual routine web browsing, etc. I doubt there will be a need to overclock this one soon. Any comments/suggestions would be appreciated.
Case - Lian Li PC-A17B Black Aluminum ATX Mid Tower
http://www.newegg.com/Product/...x?Item=N82E16811112164 - $170
PSU - Corsair CMPSU-750HX 750W
http://www.newegg.com/Product/...x?Item=N82E16817139010 - $165
CPU - Intel Core i7 920 Nehalem 2.66GHz LGA 1366
http://www.newegg.com/Product/...x?Item=N82E16819115202 - $280
Video - Sapphire 100269SR Radeon HD 4890 1GB
http://www.newegg.com/Product/...x?Item=N82E16814102830 - $210
RAM - OCZ Platinum 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
http://www.newegg.com/Product/...x?Item=N82E16820227381 - $120
CPU Cooler - Zalman CNPS9500 AT
http://www.newegg.com/Product/...x?Item=N82E16835118003 - $40
Hard Drive - Western Digital Caviar Black WD1001FALS 1TB 7200 RPM SATA
http://www.newegg.com/Product/...x?Item=N82E16822136284 - $100
LCD - Already have a 24" Dell LCD.
The one remaining part that I'm not quite sure about is the motherboard. I narrowed it down to 3 choices.
Gigabyte GA-EX58-UD5 LGA 1366
http://www.newegg.com/Product/...x?Item=N82E16813128362 - $290
Biostar TpowerX58 LGA 1366
http://www.newegg.com/Product/...x?Item=N82E16813138135 - $250
ASRock X58 Deluxe LGA 1366
http://www.newegg.com/Product/...x?Item=N82E16813157155 - $220
