Hey all, long time reader, first time poster!
So I've been through the general "system builder's post" and came up with a general setup that I'm doing for my brother.
1. PC will be used for everyday non demanding program works and frequent gaming.
2. Budget is at most $2500-3000, but I wouldn't want to spend more than what I need to.
3. Parts will be purchased from USA.
4. I'm personally closet AMD fanboy (still running on athlon 64 3200+ baby), but will be getting Intel setup and moving on myself
Other brands, probably nVidia, Seagate... doesn't matter, whatever the better product is now.
5. No current parts. He is coming from an old laptop. THIS WILL BE FRESH BUILD!
6. Yes I have searched and researched.
7. Light Overclocking? I will be taking suggestions.
Summary:
Basically, this is a fresh build from nothing. It just needs to perform your typical internet surfing and word processing or whatever. However, this rig also needs to be game friendly at a pretty good setting. I thought about going through the C2D or C2Q setup, but I'm reading that if this is a fresh build, mind as well go for the i7.
CPU: Intel Core i7 920
Seems like I don't have much choice in this category.
Heatsink: Cooler Master V8 (RR-UV8-XBU1-GP)
Seems to have good reviews?
Motherboard: ASUS P6T Deluxe V2 LGA 1366 Intel X58 ATX
Seems to be the popular choice.
Memory OCZ Platinum 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
Right off the System Build list.
Power Supply Corsair Memory CMPSU-650TX
Case Cooler Master Stacker 830 Evolution
Honestly, I'm not sure which case to get. Looks wise, this or Cosmos 1000 are appealing. So if there are other cases that are better with similar aesthetics, feel free to recommend.
Primary HD Western Digital VelociRaptor WD3000HLFS 300GB 10000 RPM 16MB Cache SATA 3.0Gb
Secondary HD Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM 16MB Cache SATA 3.0Gb
-not sure if we'll need to do any RAID setup
Primary Optical LG GH22NS30
Video Card BFG Tech BFGEGTX2851024OCXE
-been out of touch with the vid card marathon. Seems like ati has caught up to a certain degree, so I'm not sure if this is the right choice. He'll be playing games like Fallout 3 and such and it doesn't have to run at MAXIMUM setting possible. Just a pretty darn good setting. Would he need SLi setup or just a single card will do?
Then there are your usual extra fans for the case, thermal, blah blah blah.
Let me know if I need to provide you guys with more information!
Also, I welcome any suggestions on trimming the cost anywhere. If there are any parts where its performance isn't worth the price and have a substitution in mind, let me know.
Thanks in advance!!
Summary:
Thanks in advance!!
