tyl998
So I'm trying to overclock my system and I'm a complete newbie at OCing. I've tried several configurations and here is my latest one. It's very unstable and I get Blue Screen of Deaths every few minutes without even doing anything intensive, and I'm wondering what I'm doing wrong. Had to reset to optimized defaults to be able to post here.
My system is in my sig, but the two important things are i7 930 with a GA-x58a-UD3R rev2.0 mobo
Note: This screenshot was taken before I upped the VCore voltage from 1.19375V to 1.3V
Any advice would be appreciated!
Code:
Advanced CPU Features {Press Enter]
CPU Clock Ratio............................: x21
CPU Frequency .....(Ghz)...................: 3.99
Intel(R) Turbo Boost Tech..................: Disabled
CPU Cores Enabled..........................: 4
CPU Multi Threading........................: Enabled
CPU Enhanced Halt (C1E)....................: Disabled
C3/C6/C7 State Support.....................: Disabled
CPU Thermal Monitor........................: Enabled
CPU EIST Function..........................: Disabled
Bi-Directional PROCHOT.....................: Enabled
Virtualization Technology..................: Enabled
Uncore & QPI Features [Press Enter]
QPI Clock Ratio*...........................: [Auto]
QPI Link Speed* ......................(Ghz): 6.84
Uncore Clock Ratio.........................: x20
Uncore Frequency......................(Mhz): 3800
Isochronous Support........................: Enabled
Advanced Clock Control [Press Enter]
>>>>>Standard Clock Control
Base Clock (BCLK) Control*.................: Enabled
BCLK Frequency (Mhz)*......................: 190
PCI Exxpress Frequency (Mhz)...............: [Auto]
CPU Clock Drive (mV).......................: 800
PCI Express Clock Drive (mV)..............: 900
CPU Clock Skew (ps)........................: 0
IOH Clock Skew (ps)........................: 0
Advanced Dram Features [Press Enter}
Performance Enhance........................: Standard
Extreme Memory Profile (X.M.P.)............: <cant find>
System Memory Multiplier (SPD).............: x6
Memory Frequency (Mhz).....................: 1140
DRAM Timing Selectable (sPD) ..............: [Auto]
Channel Interleaving............................: 6 [Auto]
Rank Interleaving................................: 4 [Auto]
Channel A Timing Settings Sub Menu [Press Enter]
>>>>>Channel A Standard Timing Control
Cas Latency Time.............................: 8 [Auto]
tRCD.........................................: 8 [Auto]
tRP..........................................: 8 [Auto]
tRAS.........................................: 20 [Auto]
>>>>>Channel A Advanced Timing Control
tRC..........................................: 27 [Auto]
tRRD ........................................: 4 [Auto]
tWTR ........................................: 4 [Auto]
tWR..........................................: 8 [Auto]
tWTP.........................................: 19 [Auto]
tWL..........................................: 7 [Auto]
tRFC.........................................: 60 [Auto]
tRTP.........................................: 4 [Auto]
tFAW.........................................: 20 [Auto]
Command Rate (CMD) .....................: 1 [Auto]
>>>>>Channel A Misc Timing Control
B2B CAS Delay................................: - [Auto]
Round Trip Latency...........................: 86 [Auto]
Channel A Turnaround Setting [Press Enter]
>>>>> Channel A Reads Followed By Reads
Different DIMMs..............................: 6 [Auto]
Different Ranks..............................: 5 [Auto]
On The Same Rank.............................: 1 [Auto]
>>>>> Channel A Writes Followed By Writes
Different Ranks..............................: 6 [Auto]
Channel B Timing Settings Sub Menu [Press Enter]
>>>>>Channel B Standard Timing Control
Cas Latency Time.............................: <same as A>
>>>>>Channel B Advanced Timing Control
Command Rate (CMD) ..........................:
>>>>>Channel B Misc Timing Control
Round Trip Latency...........................: 89
Channel B Turnaround Setting [Press Enter]
>>>>> Channel B Reads Followed By Reads
>>>>> Channel B Writes Followed By Writes
Channel C Timing Settings Sub Menu [Press Enter]
>>>>>Channel C Standard Timing Control
>>>>>Channel C Advanced Timing Control
>>>>>Channel C Misc Timing Control
Channel C Turnaround Setting [Press Enter]
>>>>> Channel C Reads Followed By Reads
>>>>> Channel C Writes Followed By Writes
Advanced Voltage Control [Press Enter]
>>>>CPU Voltages
LoadLine Calibration.........................: [Auto]
CPU Vcore....................................: 1.19375V [1.3V]
QPI/VTT Voltage..............................: 1.175V [1.375V]
CPU PLL......................................: 1.800V [Auto]
>>>>>MCH/ICH Voltrage
PCIE.........................................: [Normal]
QPI PLL......................................: [Normal]
IOH Core.....................................: [1.160V]
ICH I/O......................................: [Normal]
ICH Core.....................................: [Normal]
>>>>>Dram
DRAM Voltage.................................: 1.500V [Auto]
DRAM Termination.............................: 0.750V [Auto]
Ch-A Data Vref...............................: 0.750V [Auto]
Ch-B Data Vref...............................: 0.750V [Auto]
Ch-C Data VRef...............................: 0.750V [Auto]
Ch-A Address Vref............................: 0.750V [Auto]
Ch-B Address Vref............................: 0.750V [Auto]
Ch-C Address VRef............................: 0.750V [Auto]
